william
in reply to: william
Full code below. Export face as DXF
'CREDITS:
'Code By @ClintBrown3D
'Originally posted at https://clintbrown.co.uk/dxf-export
'Mouse input code based on this forum post: https://forums.autodesk.com/t5/inventor-customization/ilogic-to-handle-mouse-event-for-part-selection/td-p/3902918
'Additonal DXF info via 'https://forums.autodesk.com/t5/inventor-customization/export-face-as-dxf-from-api/td-p/1965512
Start :
Error0 = 1
On Error GoTo error1
ThisApplication.StatusBarText = "Select a Face to Export as DXF"
Dim doc = ThisApplication.ActiveDocument
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Face to Export as DXF")
doc.SelectSet.Select(entity)
Dim oFace As Face
oFace = doc.SelectSet(1)
	If Not oFace.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
		MessageBox.Show("A planar face must be selected, the rule will exit", "Error Handling")
		Return
	End If
strSBName = oFace.SurfaceBody.Name
strSBNameArray = strSBName.Split("_")
strSBNameArrayCount = UBound(strSBNameArray)
strDefaultFileName = strSBNameArray(strSBNameArrayCount) 'gets the last element in the array
SetTheFilePathHere = ThisDoc.Path
SetTheFilenameHere = InputBox("Enter the file name", "Face to DXF Export",strDefaultFileName)
ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, SetTheFilePathHere &"\" & SetTheFilenameHere & ".dxf")
ThisApplication.StatusBarText = "Exporting your DXF, please hold"
Dim oCtrlDef As ButtonDefinition
oCtrlDef =
ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
oCtrlDef.Execute
Error0 = 0
MessageBox.Show("Success! - DXF exported", "Face to DXF Export")
ThisApplication.StatusBarText = "Success! - DXF exported"
InventorVb.DocumentUpdate(False)
Q = MessageBox.Show("Select another face?", "Face to DXF Export",MessageBoxButtons.YesNo)
If Q = vbYes Then
	GoTo Start
End If
error1 :
If Error0 = 1 Then
MessageBox.Show("iLogic Rule Cancelled", "Face to DXF Export")
End If
