01-20-2022
04:48 PM
- Mute
- Permalink
- Report
01-20-2022
04:48 PM
Hello All
I am looking to select a face in either an assembly or part environment, and extract the solid body name from the selected face.
The difficulty I have run into is, in an assembly the selected face is a kFaceProxyObject and in a part it is a kFaceObject.
Is there an easy way to access the solid/surface body it belongs to and report the name?
Any tips?
Links to related threads below
Inventor 2019 Help | Proxies | Autodesk
Solved: iLogic - obtain solid body name using selected feature - Autodesk Community - Inventor
Where I have got to so far with the code,
ThisApplication.StatusBarText = "Select a Face" Dim doc = ThisApplication.ActiveDocument Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Face") doc.SelectSet.Select(entity) Dim oSelectSet As SelectSet = doc.SelectSet Dim Types As ObjectTypeEnum() = [Enum].GetValues(GetType(ObjectTypeEnum)) For Each obj As Object In oSelectSet For Each Type As ObjectTypeEnum In Types If obj.Type = Type Then MsgBox(Type.ToString) End If Next Next
