A.Acheson
in reply to: fred.markle
You will need to get the bottom left corner and then subtract the length of the revision block. Here is a sub routine to do that. Hopefully that works for you.
Private Sub Positiontable(oSheet As Sheet)
Dim oPartsTable As PartsList
Set oPartsTable = oSheet.PartsLists.Item(1)
Dim oWidthPartsTable As Double
 oWidthPartsTable = oPartsTable.RangeBox.MaxPoint.X - oPartsTable.RangeBox.MinPoint.X
Dim oHeightPartsTable As Double
oHeightPartsTable = oPartsTable.RangeBox.MaxPoint.Y - oPartsTable.RangeBox.MinPoint.Y
Set oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Border.RangeBox.MinPoint.X + oWidthPartsTable, oSheet.TitleBlock.RangeBox.MinPoint.Y + oHeightPartsTable)
oPartsTable.Position = oTablePt
End Sub
Regards
Alan
