A.Acheson
in reply to: fred.markle
It might be better to add the partslist directly with the API as with the command you would still need to position and set the style manually. Here is a forum post for that
There is lots of settings to set up the parts list so here is the API help as well.
Below is the API sample.
This sample demonstrates the creation of a parts list. The parts list is placed at the top right corner of the border if one exists, else it is placed at the top right corner of the sheet. Code Samples
To run this sample, have a drawing document open. The active sheet in the drawing should have at least one drawing view and the first drawing view on the sheet should not be a draft view.
Public Sub CreatePartsList()
    On Error Resume Next
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    ' Set a reference to the first drawing view on
    ' the sheet. This assumes the first drawing
    ' view on the sheet is not a draft view.
    Dim oDrawingView As DrawingView
    Set oDrawingView = oSheet.DrawingViews(1)
    ' Set a reference to th sheet's border
    Dim oBorder As Border
    Set oBorder = oSheet.Border
    Dim oPlacementPoint As Point2d
    If Not oBorder Is Nothing Then
        ' A border exists. The placement point
        ' is the top-right corner of the border.
        Set oPlacementPoint = oBorder.RangeBox.MaxPoint
    Else
        ' There is no border. The placement point
        ' is the top-right corner of the sheet.
        Set oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.height)
    End If
    ' Create the parts list.
    Dim oPartsList As PartsList
    Set oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
End Sub
Regards
Alan
