WCrihfield
in reply to: mr_ensing
Usually when it won't accept the new HoleTapInfo you created, it is because it can't find a single entry (row) in the 'thread.xls' file that matches all specifications in that HoleTapInfo.  You mentioned that you have edited the thread.xls file before.  Is that file still in the same location and still named exactly the same as how it was installed by Inventor?  The location of the 'Design Data' folder is specified in 2 main locations (Project settings, & Application Options - File tab), but I don't recall seeing a separate setting that would allow you to specify a different file to use instead of this one.
Wesley Crihfield
(Not an Autodesk Employee)
