mblaptok
236 Views, 1 Reply
edit helicalcurve
I made sketch3D, then helicalcurve, definition Spiral.
At one of ends, i made WorkPlane, then Sketch2D on it, project geometry (point), draw a circle, and lastly made a sweep.
When i edit rotation of spiral by user interface, all update fine !
but when i change rotation by below iLogic code, WorkPlane and Sweep is lost - i need to redefine them once again.
What is missing in the ilogic code so that the result is the same as in user interface???
Dim oPDoc As PartDocument = ThisDoc.Document
oPDoc.ComponentDefinition.Sketches3D.Item(1).HelicalCurves.Item(1).Definition.Clockwise = 1
cidhelp
in reply to: mblaptok
Hi @mblaptok ,
I use Inventor 2021.3.1 an there is no problem switching the direction of a helical curve using iLogic. Workplane, 2D-Sketch and Sweeping are updating correctly.
See my screencast: https://autode.sk/33a3RVK
Attached part file including the iLogic rule.
