Richard.MM
in reply to: maxim.teleguz
I am sending the code we are using and it works.
MsgBox outputs are written in Czech language.
 Public Sub GetWhereUsed(m_inventorApp_rr As Inventor.Application)
        m_inventorApp = m_inventorApp_rr
        m_inventorApp.Visible = True
        Dim oDoc As Inventor.Document
        oDoc = m_inventorApp.ActiveDocument
        If m_inventorApp.ActiveDocument.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
            MessageBox.Show("Zdarec, máš otevřený výkres, akce bude přerušena", "Nespi!", MessageBoxButtons.OK, MessageBoxIcon.Error)
            Exit Sub
        End If
        Dim hledam As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) + System.IO.Path.GetExtension(oDoc.FullFileName)
        Dim results As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("xxxxx", "yyyyy", "zzzzz", "wwwww",
        VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication,
        Nothing)
        If Not results.Success Then
            MsgBox("Připojení k Vaultu se nezdařilo")
        End If
          connection = results.Connection
        Dim Defss As PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("ITEM")
        Dim Prop As PropDef = Nothing
        For Each def As PropDef In Defss
            If def.DispName = "Revision" Then
                Prop = def
            End If
        Next def
        Dim searchCondition As SrchCond = New SrchCond()
        searchCondition.PropDefId = Prop.Id
        defs = connection.WebServiceManager.PropertyService.FindPropertyDefinitionsBySystemNames("FILE", {"ClientFileName"})
        srchCond.PropDefId = defs(0).Id
        srchCond.PropTyp = PropertySearchType.SingleProperty
        srchCond.SrchRule = SearchRuleType.Must
        srchCond.SrchOper = 3
        srchCond.SrchTxt = hledam
        SrcConds(0) = srchCond
        Try
            files = connection.WebServiceManager.DocumentService.FindFilesBySearchConditions(SrcConds,
        Nothing,
        Nothing,
        True,
        True,
        bookmark,
        searchStatus)
        Catch
            MsgBox("Nemohu ziskat soubor z Vaultu")
        End Try
        Dim assocArray2 As FileAssocArray() = Nothing
        For Each chci In files
            If chci.Name = hledam Then
                assocArray2 = connection.WebServiceManager.DocumentService.GetLatestFileAssociationsByMasterIds(New Long() {chci.MasterId},
        FileAssociationTypeEnum.All,
        True,
        FileAssociationTypeEnum.None,
        True,
        True,
        True,
        True)
            End If
        Next
        If assocArray2(0).FileAssocs Is Nothing Then
            MessageBox.Show("Nemohu najít žádný výkres, zřejmě to budš muset udělat ručně!")
            Return
        End If
        Dim vykresy(assocArray2(0).FileAssocs.Count) As String
        If Not assocArray2 Is Nothing Then
             For i = 0 To assocArray2(0).FileAssocs.Count - 1
                If assocArray2(0).FileAssocs(i).ParFile.Name.EndsWith("idw") Then
                    If Not assocArray2(0).FileAssocs(i).ParFile.Name Is Nothing Then
                        vykresy(i) = assocArray2(0).FileAssocs(i).ParFile.Name
                    End If
                End If
            Next
        Else
            MessageBox.Show("Nemohu najít žádný výkres.")
            Exit Sub
        End If
        Dim arr As New ArrayList
        For i As Integer = 0 To vykresy.Length - 1
            If Not arr.Contains(vykresy.GetValue(i)) Then
                arr.Add(vykresy.GetValue(i))
            End If
        Next
        vykresy = arr.ToArray(GetType(String))
        Me.Show()
        Dim prvni As Integer = 0
        For Each sr In vykresy
            prvni = prvni + 1
            If Not sr Is Nothing Then
                If prvni = 1 Then
                    Me.CheckedListBox1.Items.Add(sr, True)
                Else
                    Me.CheckedListBox1.Items.Add(sr, False)
                End If
            End If
        Next
        TextBox1.AppendText(System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) + ".idw")
    End Sub
