12-29-2021
03:12 PM
- Mute
- Permalink
- Report
12-29-2021
03:12 PM
How can I best do this in VBA?
Probably not the answer that you would expect but, I think you should not use VBA at all. I wrote a blog post "Is VBA in Inventor obsolete?". In that post, I explain why I think you should not use VBA. (And maybe you want to read the follow-up post "Writing and debugging iLogic rules" as well)
And how can I get to the path of the file itself?
Have a look at the following rule:
Public Sub Main() Dim doc As AssemblyDocument = ThisDoc.Document Dim topNode = doc.BrowserPanes.Item("Model").TopNode Dim nodes = GetModelsRecursive(topNode) For Each node As BrowserNode In nodes Try Dim occ As ComponentOccurrence = node.NativeObject Dim refDoc As Document = occ.Definition.Document Dim fileName = refDoc.FullFileName logger.Info(fileName) Catch ex As Exception ' exceptions get thrown when a occurence is suppressed. logger.Info("Someting went wrong on node: " & node.FullPath) End Try Next End Sub Public Function GetModelsRecursive(node As BrowserNode) As List(Of BrowserNode) Dim nodes As New List(Of BrowserNode) For Each subNode As BrowserNode In node.BrowserNodes Try If (TypeOf subNode.NativeObject Is ComponentOccurrence) Then nodes.Add(subNode) nodes.AddRange(GetModelsRecursive(subNode)) End If If (TypeOf subNode.NativeObject Is OccurrencePattern) Then nodes.AddRange(GetModelsRecursive(subNode)) End If If (TypeOf subNode.NativeObject Is OccurrencePatternElement) Then nodes.AddRange(GetModelsRecursive(subNode)) End If Catch ex As Exception End Try Next Return nodes End Function
Jelte de Jong
Blog: hjalte.nl - github.com
