12-29-2021
12:51 AM
- Mute
- Permalink
- Report
12-29-2021
12:51 AM
Hello
I think the code is almost correct. I've added an additional check. If the name of the model state is not "master" and also the name of the model state does not contain "In-Process", it will place the component with this model state.
Option Explicit On
If ThisDoc.Document.DocumentType = kAssemblyDocumentObject
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oPDoc As PartDocument
Dim oDoc As Document
For Each oDoc In ThisApplication.Documents
If oDoc.FullFileName = "C:\Work\Inventor\TEMP\assembly test\part test.ipt" Then
oPDoc = DirectCast(oDoc, Inventor.PartDocument)
Exit For
End If
Next
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim sActiveModelState As String= oPDef.ModelStates.ActiveModelState.Name
Dim ModelStateComponent(0 To 4)
Dim addCompB = True
Dim j As Integer = 1
If oPDef.ModelStates.Count > 1
For i = 1 To oPDef.ModelStates.Count
If oPDef.ModelStates.Item(i).Name = sActiveModelState Then
' Do Nothing because the in-process part doesn't need to be added to the assembly
Else
If Not oPDef.ModelStates.Item(i).Name = "Master" And Not oPDef.ModelStates.Item(i).Name.Contains("In-Process") Then
'ModelStateComponent(i-1) = Components.AddWithModelState("Part:" & i, "part test.ipt", "Section " & i, , True)
ModelStateComponent(i - 1) = Components.AddWithModelState("Part:" & j, oPDoc.FullFileName, oPDef.ModelStates.Item(i).Name, , True)
j += 1
End If
End If
Next
Else
Dim componentA = Components.Add("Part:1", "part test.ipt", , True)
End If
Else
MessageBox.Show("This rule should only be run in an assembly document.")
End If
R. Krieg
RKW Solutions
www.rkw-solutions.com
