Hello
Don't know if I understand, but just try :slightly_smiling_face:
I used a separate integer to number the occurrences. Otherwise there are numbers missing if skipped a modelstate. I also used the original modelstate name, not create it. Created name could be a point of failure.
If ThisDoc.Document.DocumentType = kAssemblyDocumentObject
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim oDef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	'Dim oPDoc As PartDocument = ThisApplication.Documents.ItemByName("C:\Work\Inventor\TEMP\assembly test\part test.ipt")
	Dim oDoc As Document
	For Each oDoc In ThisApplication.Documents
		If oDoc.FullFileName = "C:\Work\Inventor\TEMP\assembly test\part test.ipt" Then
			opdoc = DirectCast(oDoc, Inventor.PartDocument)
			Exit For
		End If
	Next
	Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
	Dim sActiveModelState As String= oPDef.ModelStates.ActiveModelState.Name
	Dim ModelStateComponent(0 To 4)
	Dim addCompB = True
	Dim j As Integer = 1
	If oPDef.ModelStates.Count > 1
		For i = 1 To oPDef.ModelStates.Count
			If oPDef.ModelStates.Item(i).Name = sActiveModelState  Then
				' Do Nothing because the in-process part doesn't need to be added to the assembly
			Else
				'ModelStateComponent(i-1) = Components.AddWithModelState("Part:" & i, "part test.ipt", "Section " & i, , True)
				ModelStateComponent(i - 1) = Components.AddWithModelState("Part:" & j, oPDoc.FullFileName, oPDef.ModelStates.Item(i).Name, , True)
				j+=1
			End If
		Next
	Else
		Dim componentA = Components.Add("Part:1", "part test.ipt", , True)
	End If
Else
	MessageBox.Show("This rule should only be run in an assembly document.")
End If
R. Krieg
RKW Solutions
www.rkw-solutions.com
