12-23-2021
02:15 PM
- Mute
- Permalink
- Report
12-23-2021
02:15 PM
You can do it like this:
Dim doc As AssemblyDocument = ThisDoc.Document Dim occurrences = doc.ComponentDefinition.Occurrences ' Summary: ' Method that adds a new occurrence into the assembly. This method is the equivalent ' of using the Place Component command with the "Use iMate" check box checked. ' The method returns a failure if no matches are found. ' ' Parameters: ' FullDocumentName: ' Input string that specifies the full document name of the part or the sub-assembly. ' If only the FullFileName is specified, the master document within the file is ' used. ' ' PlaceAllMatching: ' Optional input Boolean that indicates whether to place multiple components corresponding ' to all iMate definition matches in the assembly. If specified to be True, multiple ' ComponentOccurrences could be returned. If specified to be False, a single ComponentOccurrence ' corresponding to the first match is returned. ' ' Options: ' Input NameValueMap object that specifies additional options for creating the ' occurrence. (An empty NameValueMap object can be provided). See Remarks for valid ' options. occurrences.AddUsingiMates(FullDocumentName)
Jelte de Jong
Blog: hjalte.nl - github.com
