logan.andersonD3CSK
747 Views, 4 Replies
Find Names of All Model States in Component from Assembly Level
Hello!
In my work, I commonly make part files with multiple model states representing different sections of the same assembly that I need to be able to pull into an assembly, but the number of sections varies depending on the assembly. The catch is that in the same part file I may or may not have in-process model states for each of those sections as well. I'm working on making a rule to automatically place the sections into an assembly, but I haven't been able to figure out how to ignore the in-process model states.
Below is what I have so far that already works as long as I don't have any in-process model states. The lines that are commented out are where I was attempting to figure out how to read the names of the model states in the component.
If ThisDoc.Document.DocumentType = kAssemblyDocumentObject
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim oDef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	Dim oPDoc As PartDocument = ThisApplication.Documents.ItemByName("C:\Work\Inventor\TEMP\assembly test\part test.ipt")
	Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
	Dim ModelStateComponent(0 To 4)
	If oPDef.ModelStates.Count > 1
		For i = 1 To oPDef.ModelStates.Count - 1
'			If oPDef.ModelStates.
'				' Do Nothing because the in-process part doesn't need to be added to the assembly
'			Else
				ModelStateComponent(i-1) = Components.AddWithModelState("Part:" & i, "part test.ipt", "Section " & i, , True)
'			End If
		Next
	Else
		Dim componentA = Components.Add("Part:1", "part test.ipt", , True)
	End If
Else
	MessageBox.Show("This rule should only be run in an assembly document.")
End If
Let me know if I need to explain a little more, or if there are any questions.
Any help would be greatly appreciated!
Labels (3)
