- Mute
- Permalink
- Report
I'm trying to call a function from a button I added into a form, the problem is that the handler doesn't allow me to call that function because it requires external parameters, which the handler can't read due to input restrictions.
How can I fix this?
Some code sample:
Public Sub Button
Dim oButton1 As New Button() oForm.Controls.Add(oButton1) AddHandler oButton1.Click, AddressOf oButton1_Click
End Sub
Public Sub oButton1_Click(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) Call MyClickFunction(oParam) End Sub
- Mute
- Permalink
- Report
I guess this is a follow up to your other question. I don't understand your exact problem. but I figured I could show off some solutions for passing parameters around.
Notice
- I defined the variable _occName in the class (not in a function) therefore it's available in all functions. it is set and in the sub New and was used in the function MyClickFunction
- I defined the public property MyProperty. this is set in the MyClickFunction but used out site the winform class in the rule.
Hopefully you answer is solved like this.
Public Sub Main() '//////// GET THE OCCURRENCE NAME //////// Dim occ As ComponentOccurrence = ThisApplication.CommandManager.Pick( SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select occurrence") Dim occName As String = occ.Name '//////// RUN THE FORM //////// Dim oForm As New WinForm(occName) oForm.ShowDialog() MsgBox(oForm.MyProperty) End Sub Public Class WinForm Inherits System.Windows.Forms.Form Public oLargerFont As System.Drawing.Font = New Font("Arial", 10) Private _occName As String Public Property MyProperty As String '//////// CREATE NEW INSTANCE //////// Public Sub New(occName As String) oForm = Me _occName = occName '//////// PARAMETERS FOR THE FORM //////// With oForm .FormBorderStyle = FormBorderStyle.FixedToolWindow .StartPosition = FormStartPosition.CenterScreen .Width = 300 .Height = 700 .TopMost = True .Font = oLargerFont .Text = "Component Select" .Name = "Components" .ShowInTaskbar = False End With Dim oButton1 As New Button() With oButton1 .Text = "MODIFY" .Top = 25 .Left = 25 .Enabled = True .AutoSize = True End With oForm.Controls.Add(oButton1) AddHandler oButton1.Click, AddressOf oButton1_Click Dim oOptions As New List(Of String) oOptions.AddRange({"Option 1","Option 2","Option 3"}) Dim oGroupBox As GroupBox = New GroupBox() oGroupBox.Left = 25 oGroupBox.Width = 150 oGroupBox.Top = oButton1.Bottom + 20 oGroupBox.Height = 100 oGroupBox.Text = "Choose" oForm.Controls.Add(oGroupBox) '//////// RADIOBUTTON PARAMETERS //////// Dim oRadioButton1 As New RadioButton() oGroupBox.Controls.Add(oRadioButton1) oRadioButton1.Text = occName oRadioButton1.Top = 20 oRadioButton1.Left = 35 oRadioButton1.AutoSize = True End Sub Private Sub oButton1_Click(ByVal oSender As System.Object, ByVal oEventArgs As System.EventArgs) MyClickFunction("My param") End Sub Private Sub MyClickFunction(oParam As String) MsgBox(_occName + " : " + oParam) MyProperty = "I set my property here but it is used in the rule class" End Sub End Class
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
That was really helpful, now I can access my data between classes and functions. Thank you.
