JelteDeJong
in reply to: j.pavlicek
the problem here is that:
occ.ReferencedDocumentDescriptor.ReferencedDocument
returns an object instead of a document (as you might expect). Anyway, the following might be a bit cleaner code:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim refDocs = doc.ComponentDefinition.Occurrences.Cast(Of ComponentOccurrence).
    Select(Of Document)(Function(occ) occ.ReferencedDocumentDescriptor.ReferencedDocument).
    Distinct().ToList()
For Each refDoc As Document In refDocs
    Logger.Info(refDoc.DisplayName)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
