12-21-2021
04:29 AM
- Mute
- Permalink
- Report
12-21-2021
04:29 AM
- .Cast(of ComponentOccurrence)
- Converts the ComponentOccurrences object to the object IEnumerable(of ComponentOccurrence). That allows us to use the LINQ functions of vb.net
- .Select(Function(occ) occ.ReferencedDocumentDescriptor.ReferencedDocument)
- This will create an IEnumerable(of Document). The documents are selected from the occurrences.
- Distinct()
- Will remove all duplicates from the list. You will have duplicates if you use 1 document for multiple occurrences
- .ToList()
- This will convert the object IEnumerable(of Document) to a List(of Document). Strictly this is not needed as you can loop over an IEnumerable(of Document) but because LINQ is lazy it will only do all the above when you create a list. (or start using the IEnumerable like in a for/each loop). I experienced some extra performances when I used a List instead of the IEnumerable
Jelte de Jong
Blog: hjalte.nl - github.com
