A.Acheson
in reply to: syafiqfarhan
Here you go. Error were likely declarations in the wrong place. Hopefully you can check this tested one to see where it went wrong.
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet
Dim oSheets As Sheets
Dim oView As DrawingView
Dim oViews As DrawingViews
Dim oScale As Double
oScale = InputBox("Enter Desired Scale", "Scaler", "1")
oSheet = oDrawDoc.ActiveSheet
oViews = oSheet.DrawingViews
For Each oView In oViews
   If oView.ScaleFromBase = False Then
       oView.Scale = oScale
   End If
Next
Regards
Alan
