12-14-2021
11:04 PM
- Mute
- Permalink
- Report
12-14-2021
11:04 PM
Dim oPartDoc As Document oPartDoc = ThisDoc.Document If oPartDoc.DocumentType = kPartDocumentObject Then Dim oPartCompDef As PartComponentDefinition oPartCompDef = oPartDoc.ComponentDefinition Dim oParams As Parameters oParams=oPartCompDef.Parameters Dim oUserParams As UserParameters oUserParams=oParams.UserParameters Dim oAwesomeParameter As Parameter Try otester = oUserParams.Item("Profile") Catch oInsulationType=oUserParams.AddByValue("Profile", "Plate", kTextUnits) MultiValue.SetList("Profile", "Plate", "HEA", "HEB", "Pipe", "Sample") End Try End If Parameter.Param("Profile").ExposedAsProperty = False Parameter.Param("Profile").IsKey = True If oPartDoc.DocumentType = kPartDocumentObject Then Dim oPartCompDef As PartComponentDefinition oPartCompDef = oPartDoc.ComponentDefinition Dim oParams As Parameters oParams=oPartCompDef.Parameters Dim oUserParams As UserParameters oUserParams=oParams.UserParameters Dim oAwesomeParameter As Parameter Try otester = oUserParams.Item("t") Catch oInsulationType = oUserParams.AddByValue("t", " ", kTextUnits) End Try End If Parameter.Param("t").ExposedAsProperty = False Parameter.Param("t").IsKey = True If oPartDoc.DocumentType = kPartDocumentObject Then Dim oPartCompDef As PartComponentDefinition oPartCompDef = oPartDoc.ComponentDefinition Dim oParams As Parameters oParams=oPartCompDef.Parameters Dim oUserParams As UserParameters oUserParams=oParams.UserParameters Dim oAwesomeParameter As Parameter Try otester = oUserParams.Item("Unit") Catch oInsulationType=oUserParams.AddByValue("Unit", "MM", kTextUnits) MultiValue.SetList("Unit", "MM", "INCH", "Sample") End Try End If Parameter.Param("Unit").ExposedAsProperty = False Parameter.Param("Unit").IsKey = True
Hi all, I want to make my "t" value link to my iproperties. Is there a possible way?
