12-07-2021
04:08 AM
- Mute
- Permalink
- Report
12-07-2021
04:08 AM
revision table style doesn't change the table
I add a rev-table with Ilogic and it works quite ok. The table is created and placed correctly, but the style seems not to work.
The style is set correct, but the the view of the table is wrong. If I click the style once again with the mouse, the table is in shown correct style.
Where is the problem?
Dim oApp As Application Dim oDoc As DrawingDocument Dim oSheet As Sheet Dim oRevTable As RevisionTable Dim myPoint As Inventor.Point2d Dim oRevTableId As RevisionTableStyle Dim oRevStart As String 'Dim oRevTableLayer As Layer oApp = ThisApplication oDoc = ThisDoc.Document oSheet = oDoc.ActiveSheet If oSheet.RevisionTables.Count = 0 Then 'MsgBox("There is no RevisionTable on this sheet.") myPoint = oApp.TransientGeometry.CreatePoint2d(0, 0) oRevTableId = oDoc.StylesManager.RevisionTableStyles.Item("FW_Revisionstabelle") 'oRevStart = "00" oRevTable = oSheet.RevisionTables.Add2(myPoint, False, False, False, "00",oRevTableId) 'oRevTable.Layer = "Titel (ISO)" 'Exit Sub End If
after clicking the style once again
12-07-2021
02:51 PM
- Mute
- Permalink
- Report
12-07-2021
02:51 PM
I am not sure why put trying to target a style that is not the default style on placing fails to work. So if you place a style as default then reference the style and change it to a new one this works.
'add a new table Dim oRevTable As RevisionTable oRevTable = oSheet.RevisionTables.Add2(oTablePt, False, True, True, "0" )'oLocation 'Get revision table oRevTable = oSheet.RevisionTables.Item(1) 'Get New Style
Dim oRevStyle As RevisionTableStyle oRevStyle = oDrawDoc.StylesManager.RevisionTableStyles.Item("B Size Revision Table (ANSI)") 'Change RevTable Style oRevTable.Style = oRevStyle
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
