A.Acheson
in reply to: smanionDV2GJ
Here is the command used to open that dialogue box. This code is the same as navigating and hitting the button. Here is a link to events trigger you might consider to run the command rule. If you want to change something in there that will need API access. Here is a link to locating the API help and also a good blog for ilogic. In the API help Search sheetmetal and you will find how to access there functions.
Dim oCD AS ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("SheetMetalStylesCmd")
oCD.Execute
A quick internet search found it on this forum here.
Regards
Alan
