12-01-2021
04:38 AM
- Mute
- Permalink
- Report
12-01-2021
04:38 AM
I got a problem with an external rule. That rule worked fine as internal rule, but now there's a failure at one expression
Dim oApp As Application Dim oDoc As DrawingDocument Dim oSheet As Sheet Dim oRevTable As RevisionTable Dim myPoint As Inventor.Point2d oApp = ThisApplication oDoc = ThisDoc.Document oSheet = oDoc.ActiveSheet oRevTable = oSheet.RevisionTables.Item(1) If oSheet.RevisionTables.Count = 0 Then MsgBox("There is no RevisionTable on this sheet.") Exit Sub End If Dim PointX As Double Dim PointY As Double Dim SizeX As Double Dim SizeY As Double SizeX = oRevTable.RangeBox.MaxPoint.X - oRevTable.RangeBox.MinPoint.X SizeY = oRevTable.RangeBox.MaxPoint.Y - oRevTable.RangeBox.MinPoint.Y PointX = PointX-SizeX PointY = PointY myPoint = oApp.TransientGeometry.CreatePoint2d(PointX, PointY) oRevTable.Position = myPoint
This is the failure text:
System.ArgumentException: Falscher Parameter. (Ausnahme von HRESULT: 0x80070057 (E_INVALIDARG))
bei System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
bei Inventor.RevisionTables.get_Item(Object Index)
bei ThisRule.Main()
bei Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
bei iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
