11-28-2021
05:56 PM
- Mute
- Permalink
- Report
11-28-2021
05:56 PM
I am trying to write an algorithm (subroutine) to determine if a plane intersects a solid. I have prepared the code below which measures the minimum distance between each solid face to the plane, and it works, but it is very slow, especially as parts get larger and more complex.
Does anyone have an idea for a faster solution?
Thanks in advance
Sub Main()
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim Solid1 As SurfaceBody = oCompDef.SurfaceBodies(1)
Dim Plane As WorkPlane = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Plane")
MessageBox.Show(PlaneIntersectSolid(Solid1,Plane),"Does Plane intersect solid 1?")
End Sub
Function PlaneIntersectSolid(Solid1 As SurfaceBody, Plane As WorkPlane) As Boolean
For Each oFace As Face In Solid1.Faces
If ThisApplication.MeasureTools.GetMinimumDistance(Plane, oFace) = 0 Then
PlaneIntersectSolid = True
Exit Function
End If
Next
PlaneIntersectSolid = False
End Function
