11-27-2021
08:25 AM
- Mute
- Permalink
- Report
11-27-2021
08:25 AM
Maybe this is what you need:
Sub Main() Dim doc As DrawingDocument = ThisDoc.Document ChangeLayer(doc, DrawingEdgeTypeEnum.kBendUpEdge, "ARRIBA") ChangeLayer(doc, DrawingEdgeTypeEnum.kBendDownEdge, "ABAJO") End Sub Private Sub ChangeLayer(doc As DrawingDocument, EdgeType As DrawingEdgeTypeEnum, layerName As String) Dim layer As Layer = doc.StylesManager.Layers.Item(layerName) Dim segments = doc.Sheets.Cast(Of Sheet). SelectMany(Function(sheet) sheet.DrawingViews.Cast(Of DrawingView)). SelectMany(Function(view) view.DrawingCurves.Cast(Of DrawingCurve)). Where(Function(curve) curve.EdgeType = EdgeType). SelectMany(Function(curve) curve.Segments.Cast(Of DrawingCurveSegment)). ToList() For Each segment As DrawingCurveSegment In segments segment.Layer = layer Next End Sub
Edit:
improved the rule
Jelte de Jong
Blog: hjalte.nl - github.com
