paul.carsonVQFZ9
492 Views, 1 Reply
Tube and Pipe fitting for different sizes
I have a socket weld fitting which can be inserted into different size pipes. At the moment I have it set for a 1 1/2" pipe with an OD of 48.3mm. The pipe centre axis is governed by this dimension, so if I want to use this now in a 2" pipe, the socket will be much lower.
What's the best way to set this up so the 48.3mm is linked to the 1 1/2" or 2" pipe changes for tube and pipe?
Tags (1)
Labels (1)
