paul.carsonVQFZ9
492 Views, 1 Reply
Tube and Pipe fitting for different sizes
I have a socket weld fitting which can be inserted into different size pipes. At the moment I have it set for a 1 1/2" pipe with an OD of 48.3mm. The pipe centre axis is governed by this dimension, so if I want to use this now in a 2" pipe, the socket will be much lower.
What's the best way to set this up so the 48.3mm is linked to the 1 1/2" or 2" pipe changes for tube and pipe?
Tags (1)
Labels (1)
In the CC you will find threadolets that have all ready being authored similar to your example. Although they may have a curve suited to the run of the pipe. These fittings are authored as branch fittings and here is some instructions here.
If I was doing this I would place from content center as custom a threadolet. Take a look at the sketch construction and the authoring of the fitting. Pay special attention to the origins points required to set authoring then replicate on a new iPart.
In the past there has been issues getting the branch fitting to recognize the run size with a branch fitting created from scratch. If this happens use a custom placed threadolet as a basis for the new iPart. Hidden attributes in the file will be used to detect run size on placement.
Here is also a blog post on authoring branch fitting which includes a video.
http://blog.ads-sol.com/2014/09/authoring-branch-fittings.html?m=1
Regards
Alan
