nmunro
in reply to: NateLFO
If you examine the exceptions a bit more closely you will see that they are all happening in Inventor dlls which are completely out of your control. No need to worry about them unless you see something with your add-in name in the exception. Even then unless it causes an issue you can generally ignore them.
https://c3mcad.com
