JelteDeJong
in reply to: iogurt1
you can try this:
Dim doc As AssemblyDocument = ThisDoc.Document
For Each oOccurrence As ComponentOccurrence In doc.ComponentDefinition.Occurrences
    If iProperties.Value(oOccurrence.Name, "Status", "Status") = "" Then
        iProperties.Value(oOccurrence.Name, "Custom", "TEST") = iProperties.Value(oOccurrence.Name, "Project", "Part Number") & iProperties.Value(oOccurrence.Name, "Project", "Revision Number")
    Else
        iProperties.Value(oOccurrence.Name, "Custom", "TEST") = iProperties.Value(oOccurrence.Name, "Project", "Part Number") & iProperties.Value(oOccurrence.Name, "Project", "Revision Number") & "_P" & iProperties.Value(oOccurrence.Name, "Status", "Status")
    End If
Next
'auf .iam Ebene
If iProperties.Value("Status", "Status") = "" Then
    iProperties.Value("Custom", "TEST") = iProperties.Value("Project", "Part Number") & iProperties.Value("Project", "Revision Number")
Else
    iProperties.Value("Custom", "TEST") = iProperties.Value("Project", "Part Number") & iProperties.Value("Project", "Revision Number") & "_P" & iProperties.Value("Status", "Status")
End If
Jelte de Jong
Blog: hjalte.nl - github.com
