iogurt1
291 Views, 2 Replies
Create custom iProperty for subcomponents & subassemblies from within parent assembly
Hey everyone. Our goal is to create a new iProperty called "TEST" in just the first level of children of an assembly. With this code, it does what we want, but it goes all the way down, if there are subassemblies with parts in them. Is it possible to only run this on the top level items? Thanks!
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all Of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
		If iProperties.Value(oOccurrence.Name, "Status", "Status") = ""
	    iProperties.Value(oOccurrence.Name, "Custom", "TEST") = iProperties.Value(oOccurrence.Name, "Project", "Part Number") & iProperties.Value(oOccurrence.Name, "Project", "Revision Number")
	    Else
	    iProperties.Value(oOccurrence.Name, "Custom", "TEST") = iProperties.Value(oOccurrence.Name, "Project", "Part Number") & iProperties.Value(oOccurrence.Name, "Project", "Revision Number") & "_P" & iProperties.Value(oOccurrence.Name, "Status", "Status")
	    End If
Next
'auf .iam Ebene
		If iProperties.Value("Status", "Status") = ""
	    iProperties.Value("Custom", "TEST") = iProperties.Value("Project", "Part Number") & iProperties.Value("Project", "Revision Number")
	    Else
	    iProperties.Value("Custom", "TEST") = iProperties.Value("Project", "Part Number") & iProperties.Value("Project", "Revision Number") & "_P" & iProperties.Value("Status", "Status")
	    End If
