A.Acheson
in reply to: cadman777
Here is two rules I am using for drawings with view reps. They seem to work well. You may need to do some customizing  of rule 1 as  there is a filter to only create views with certain names. "If oDesView.Name.Contains("SP") Then", so simply remove the if statement for all view reps.
  1. Views created from view reps
'https://forums.autodesk.com/t5/inventor-customization/ilogic-drawing-view-height-and-size-problem/td-p/9256794
'https://forums.autodesk.com/t5/inventor-forum/place-all-design-views-on-an-idw/td-p/6035731
Sub Main
	CreateViewForEachRep()
End Sub
Public Sub CreateViewForEachRep()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
     oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
     oSheet = oDrawDoc.ActiveSheet
    Dim viewScale As Double
     viewScale = 1/20
    Dim ptx As Long
     ptx = 0
    'this assumes that view1 is of the full assembly - a view must have been placed in a drawing before running this
    Dim assyDocName As String
     assyDocName = oSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.FullDocumentName
    Dim assyDoc As AssemblyDocument
    'open assembly doc invisibly
     assyDoc = ThisApplication.Documents.Open(assyDocName, False)
    Dim oAssyCompDef As AssemblyComponentDefinition
     oAssyCompDef = assyDoc.ComponentDefinition
    Dim oRepMgr As RepresentationsManager
     oRepMgr = oAssyCompDef.RepresentationsManager
    Dim oDesView As DesignViewRepresentation
    For Each oDesView In oRepMgr.DesignViewRepresentations
            Dim oPoint1 As Point2d
             oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(ptx, 11)
            Call PlaceBaseView(oSheet, assyDoc, oPoint1, oDesView.Name,viewScale)
        End If
        ptx = ptx + 6
		'ptx = ptx + 2 +(VWidth/2)
    Next
      'close assembly doc
      assyDoc.Close (False)
End Sub
Public Sub PlaceBaseView(ByRef sheet As Inventor.Sheet, _
                        ByRef assyDoc As AssemblyDocument, _
                        ByRef oPoint1 As Point2d, _
                        ByRef viewName As String, _
						ByRef viewScale As Double)
    'define view orientation
    Dim vieworient1 As ViewOrientationTypeEnum
     vieworient1 = ViewOrientationTypeEnum.kFrontViewOrientation
    'define view style
    Dim viewstyle1 As DrawingViewStyleEnum
     viewstyle1 = DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle
    Dim oFaceView As DrawingView
     oFaceView = sheet.DrawingViews.AddBaseView(assyDoc, oPoint1, viewScale, vieworient1, viewstyle1, viewName)'viewScale
	 'Set view reps associative so they update when model changes. Othewise they are a static image
	oFaceView.SetDesignViewRepresentation(viewName,True)
End Sub
2. Set View Labels based on ViewRep
'https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-math-function-to-see-what-lenght-fits-the-best/td-p/10511825
Sub Main
oDrawDoc = ThisDrawing.Document
Dim oModel As AssemblyDocument
oModel = ThisDoc.ModelDocument
Dim NameQty As New Dictionary(Of String, Double)
Dim sViewRepNames As New ArrayList
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim MFGQTY As String
Dim sViewRepName As String
oSheets = oDrawDoc.Sheets
Dim i As Integer = 0
Call TraverseBOM(oModel, NameQty)
For Each oSheet In oSheets
	oViews = oSheet.DrawingViews
    For Each oView In oViews
		'make view label visible
		 oView.ShowLabel = True
		Try
		sViewRepName = oView.ActiveDesignViewRepresentation.ToString
		'MessageBox.Show(sViewRepName, "Title")
		sViewRepNames.Add(sViewRepName)
		Catch
			MessageBox.Show("View Rep not associative" , "Title")
		End Try
		For Each pair As KeyValuePair(Of String, Double) In NameQty
		If pair.Key = sViewRepName Then
			If pair.Value = 1 Then
				sString1 = "<DrawingViewName/>"
				sString2 = sViewRepName
				'sString3 = "QTY: " & pair.Value
				'add lines to the view label
				'break line using:  "<Br/>"
			    oView.Label.FormattedText = _
			    sString1 & "<Br/>" & _
			    sString2 & "<Br/>" '& _
				'sString3 & "<Br/>"
			ElseIf pair.Value > 1 Then
			    sString2 & "<Br/>" & _
				sString3 & "<Br/>"
			End If
		End If
		Next
	Next
Next
d0 = InputListBox("Prompt", NameQty, d0, Title := "Title", ListName := "List")
d0 = InputListBox("Prompt", sViewRepNames, d0, Title := "Title", ListName := "List")
End Sub
Public Sub TraverseBOM(oModel, NameQty )
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oModel.ComponentDefinition
'[Traverse the BOM
'https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-get-properties-from-bom/td-p/9204275
For Each oBOMView As BOMView In oAsmCompDef.BOM.BOMViews
	'Logger.Info("looping through BOM")
	If oBOMView.ViewType = BOMViewTypeEnum.kStructuredBOMViewType Then
		On Error Resume Next
		For Each oBOMRow As BOMRow In oBOMView.BOMRows
			Dim oDoc As Document = oBOMRow.ComponentDefinitions.Item(1).Document
			'Logger.Info(oDoc.DisplayName)
			Dim oDTP As PropertySet = oDoc.PropertySets.Item("Design Tracking Properties")
			'Dim oItemNum As String = oBOMRow.ItemNumber
			Dim oPN As String = oDTP.Item("Part Number").Value.ToString
			Dim oDesc As String = oDTP.Item("Description").Value.ToString
			Dim Qty As String = oBOMRow.TotalQuantity
			'Deal with non numeric qty in BOM
			numericCheck = IsNumeric(Qty)
			If numericCheck = True Then
				'Add to dictionary of string,double
				'Note, the string part is so we can return a reference later.
				NameQty.Add(oPN, Qty)
			Else
			'MessageBox.Show("Input is NOT numeric.", "iLogic")
			End If
		Next
	End If
Next
End Sub
Regards
Alan
