11-09-2021
10:48 AM
- Mute
- Permalink
- Report
11-09-2021
10:48 AM
Try this:
Public Sub Main()
Dim ass As AssemblyDocument = ThisApplication.ActiveDocument
Dim RutaExport As String = ThisDoc.Path
Dim Dialog = New FolderBrowserDialog()
Dialog.SelectedPath = RutaExport
Dialog.ShowNewFolderButton = True
Dialog.Description = "Choose directory for saved .stp files"
Dialog.ShowDialog()
If DialogResult.OK Then
oPath = Dialog.SelectedPath & "\"
Else
Return
End If
Dim oselset As SelectSet = ass.SelectSet
Dim i As Integer = 0
Dim result As Boolean
Dim occ As ComponentOccurrence
If oselset.Count <> 0 Then
For Each occ In oselset
Dim doc As Document = occ.Definition.Document
result = ExportToSTEP(doc, oPath)
If result = True Then
i = i + 1
End If
Next
MessageBox.Show(i & " files successfully exported", "result")
Else
MessageBox.Show("You must select files to export before running rule", "Error")
End If
End Sub
Function ExportToSTEP(doc As Document, sPath As String) As Boolean
Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(doc, oContext, oOptions) Then
oOptions.Value("ApplicationProtocolType") = 3
oContext.Type = kFileBrowseIOMechanism
Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
uPath = Left(doc.FullDocumentName, InStrRev(doc.FullDocumentName, "\") -1)
uName = Mid(doc.FullDocumentName, Len(uPath) + 2, Len(doc.FullDocumentName) -Len(uPath) -5)
oData.FileName = sPath & uName & ".stp"
Call oSTEPTranslator.SaveCopyAs(doc, oContext, oOptions, oData)
ExportToSTEP = True
End If
End Function
