desenho33ZLER
294 Views, 0 Replies
Copy Derived Custom iProperties
Hi!
I'm trying to adapt the code from a previous Post (works like a charm on an Part File)  so that i can run it on an assembly file.  Braking it down:
I've an assembly file with multiple parts (some with derived parts, others don't) and i'm trying to run a code that:
- Checks for the file type (.ipt/.iam)
- If it's an assembly file: iterates trough the multiple parts  and copies the Custom iProperties from the derived Parts from each one.
- If it's an Part file runs the previous code, no problems there...
Here is my Sample code:
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim docFile As Document
If openDoc.DocumentType = 12291 Then
For Each docFile In openDoc.AllReferencedDocuments
If docFile.ComponentDefinition.BOMStructure <> BOMStructureEnum.kPurchasedBOMStructure
Dim oDerived As Inventor.Document = ThisApplication.ActiveDocument ' <-i think this is where my problem lies because it jumps out to the main assembly custom iProproperties
If oDerived.ReferencedDocuments.Count = 0 Then Exit Sub
Dim oReferenced As Inventor.Document = oDerived.ReferencedDocuments(1)
Dim oDerProps As PropertySet = oDerived.PropertySets.Item("Inventor User Defined Properties")
Dim oRefProps As PropertySet = oReferenced.PropertySets.Item("Inventor User Defined Properties")
Dim oProList() As String = {"*"} 'Use "*" to copy all iPros
For Each oRefPro As Inventor.Property In oRefProps
Dim oSkip As Boolean = True
For Each ProName As String In oProList
If UCase(ProName) <> UCase(oRefPro.Name) And ProName <> "*" Then Continue For
oSkip = False
Exit For
Next
If oSkip Then Continue For
Dim oDerPro As Inventor.Property
Try
oDerPro = oDerProps(oRefPro.Name)
Catch
oDerPro = oDerProps.Add("", oRefPro.Name)
End Try
oDerPro.Value = oRefPro.Value
Next
End If
Next
Else If openDoc.DocumentType = 12290 Then
Dim oProList() As String = {"Pri_CodFamilia", "Pri_Descricao","Pri_Descricao_Familia","Pri_Descricao_Marca","Pri_Descricao_TipoArtigo","Pri_RefMarca","Pri_Referencia","Pri_UnidadeBase"} 'Use "*" to copy all iPros
oSkip = False
Exit For
Next
Try
Catch
End Try
Next
Else
'MessageBox.Show("O documento Ativo tem de ser um Assembly!", "Formato de Ficheiro Errado!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
End If
Glad to anyone that can help
Labels (1)
