JelteDeJong
in reply to: pete.dehaan
Is this what you are looking for?
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
For Each revTab As RevisionTable In sheet.RevisionTables
    Dim firstRow As RevisionTableRow = revTab.RevisionTableRows.Item(1)
    ' You might need to change the (Column) numbers here.
    Dim revDate As RevisionTableCell = firstRow.Item(3)
    Dim initials As RevisionTableCell = firstRow.Item(2)
    Dim userName As String = ThisApplication.GeneralOptions.UserName
    If (String.IsNullOrEmpty(revDate.Text)) Then
        revDate.Text = DateTime.Now.ToString("yyyy-MM-dd")
    End If
    If (String.IsNullOrEmpty(initials.Text)) Then
        initials.Text = userName
    End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
