11-02-2021
01:02 PM
- Mute
- Permalink
- Report
11-02-2021
01:02 PM
Hall Theo,
thanks for the anwer. But as you mentioned the 'PromoteParameter' does not work.
I 'found' a really sketchy solution how to identify a annotation depending on a DimensionConstraint.
I guess that this solution will be very easy to break, and if the other objects
- RadiusModelDimensions
- DiameterModelDimensions
- AngularModelDimensions
will work the same way ?? I don't know
public ModelAnnotation GetConnectedAnnotation(DimensionConstraint constraint)
logger.Debug($"GetConnectedAnnotation");
var annotations = applicationService.GetDocumentAnnotations();
foreach (var md in annotations.ModelDimensions)
if (md is LinearModelDimension modelDimension)
if (modelDimension.Definition is LinearModelDimensionDefinition lmdd)
if (lmdd.IntentOne.Geometry is SketchPoint sp)
foreach (var point in constraint.AnchorPoints)
if (point is Point2d point2d)
if (sp.Geometry.IsEqualTo(point2d))
if (Math.Abs(constraint._DisplayValue - modelDimension.ModelValue) <= 0)
logger.Debug($"found constraint : {constraint.Parameter.Name} Value:'{constraint.Parameter.Expression}' | modelDimesnion{modelDimension.Name} Value :'{modelDimension.ModelValue}'");
return md as ModelAnnotation;
return null;
