brianA32ZM
225 Views, 0 Replies
Pattern Behavior iLogic
Hello, I have noticed a strange behavior when changing a pattern quantity via ilogic.
Case:
      Pattern Qty = 2
      Pattern Element 1, component A visibility = False
      Pattern Element 2, component A visibility = True
If I manually change the Pattern Qty to 1 and then back to 2:
      Pattern Element 1 ,component A visibility = False
      Pattern Element 2, component A visibility = False
This is what I expected, however if change the Pattern Qty in the same steps with iLogic:
Is there something that I am missing or is this standard behavior?
