11-01-2021
04:28 PM
- Mute
- Permalink
- Report
11-01-2021
04:28 PM
Hello
And what kind of trouble? Maybe the Reference Skeleton part has not an occurrence number in browser tree and your code crashes in this case? Then skip occurences without a number. Or that for the Reference Skeleton part a view rep is created? Then we skip all parts with BOMstructure Phantom?
I have also edited the name compare a bit.
'create a design view representation for each unique part in the assembly
'define current document
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim oTrans As Transaction=ThisApplication.TransactionManager.StartTransaction(openDoc,"Create View Rep's")
Try
'set a reference to the assembly component definintion.
'this assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'look at all of the components in the assembly
Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition
'define the first level components collection
Dim oCompOcc As Inventor.ComponentOccurrence
'define view rep
Dim oViewRep As DesignViewRepresentation
'define an arraylist to hold the list of view rep names
Dim NameList As New ArrayList()
'Look at the view reps in the assembly
For Each oViewRep In oAsmCompDef.RepresentationsManager.DesignViewRepresentations
'set the list of names to the array list
NameList.Add(oViewRep.Name)
Next
'check for a Default view rep and create it if not found
If Not NameList.Contains("Default") Then
'create Default view rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("Default")
oViewRep.ShowAll
oViewRep.Activate
End If
'zoom all
ThisApplication.CommandManager.ControlDefinitions.Item("AppIsometricViewCmd").Execute
'look at all of the unique parts in the assembly
For Each docFile In openDoc.AllReferencedDocuments
If oCompDef.Occurrences.AllReferencedOccurrences(docFile).Count > 0 Then 'avoid to create a view rep for base part of derived parts
If Not docFile.componentdefinition.bomstructure = BOMStructureEnum.kPhantomBOMStructure Then
If docFile.DocumentType = 12290 Then '12290 is the part document enumurator
'locate the last backslash position in the full file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
'remove path from part file name
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
'remove extension from part file name
ShortName = Left(docFName, Len(docFName) - 4)
'check to see if the arraylist contains the desired view rep
If Not NameList.Contains(ShortName) Then
'create new View Rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add(ShortName)
oViewRep.Activate
oViewRep.Locked = False
Else If NameList.Contains(ShortName) Then
'reference existing View Rep
oViewRep = oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item(ShortName)
oViewRep.Activate
End If
Dim bSkip As Boolean=False
'look at all of the occurences
For Each oCompOcc In oCompDef.Occurrences.AllLeafOccurrences
'locate the colon position in the occurence name
oCompOccPos = InStrRev(oCompOcc.Name, ":")
If oCompOccPos<2 Then oCompOccPos=Len(oCompOcc.Name)
'set occurence name to everything left of the colon
oOccName = Left(oCompOcc.Name, oCompOccPos -1)
'set visible if name matches first occurence
'If oCompOcc.Name = ShortName & ":1" And bSkip = False Then
If System.IO.Path.GetFileNameWithoutExtension(oCompOcc.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName) = ShortName And bSkip=False Then
oCompOcc.Visible = True
ThisApplication.ActiveView.Update()
bSkip=True 'even if there is more than one occurrence named "xyz:1" in different subassys, we want only one occurence in our view rep
Else
oCompOcc.Visible = False
End If
Next
End If
End If
'lock view rep
oViewRep.Locked = True
End If
Next
'set Default View Rep active
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Default").Activate
oTrans.End
Catch ex As Exception
MsgBox(ex.StackTrace )'Message)
oTrans.Abort
End Try
R. Krieg
RKW Solutions
www.rkw-solutions.com
