- Mute
- Permalink
- Report
'define current document Dim openDoc As AssemblyDocument openDoc = ThisAssembly.Document
And the
oCompOcc.Name = ShortName & ":1"
is not the same because the displayname is different then the part name!
put a massage box between and you will see:
msgbox (oCompOcc.Name = ShortName & ":1")
Arthur Knoors
Autodesk Affiliations:
