Holzethekid
467 Views, 3 Replies
Inventor Api: find Connection between Sketch Dimension(DimensionConstraint) and Model Dimension(LinearModelDimension)
Hallo,
since Inventor 22 it is possible to promote SketchDimensions via code. See here
Holzethekid_2-1635603755987.pngvia UI
The Model Dimensions promoted via 'Inventor' has the great feature that if i change an value in the sketch the value in the Model Value will change to.
Manuell created Model Dimensions do not have this feature.
I Assume that the Sketch Dimension (DimensionConstaint) and the Model Dimension (ModelDimension) are somehow connected.
I was checking the documentation, but i did not find any connection between the two objects.
Can somebody help me to find the connection between these objects, or how can i find out if one DimensionConstraint is already promoted and get the object ?!
Thanks in Advance
Christian
