Having some issues running rules/setting parameters on the new active model state
I have used the solution code with minor alterations:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim occ As ComponentOccurrence '= doc.ComponentDefinition.Occurrences.Item(1)
Dim oName = "COURSE 1 STEEL TANK SHEET:8"
For Each occ In doc.ComponentDefinition.Occurrences
	If occ.Name = oName Then
		Dim facDoc As PartDocument = occ.Definition.Document
		If (facDoc.ComponentDefinition.IsModelStateMember) Then
		    facDoc = facDoc.ComponentDefinition.FactoryDocument
		End If
		Dim modelStates As ModelStates = facDoc.ComponentDefinition.ModelStates
		Dim newModelStateName = "N1"
		Dim modelState As ModelState = modelStates.Add()
		modelState.Name = newModelStateName
		modelState.Activate()
		occ.ActiveModelState = newModelStateName
	End If
Next
ilogicVb.RunRule("COURSE 1 STEEL TANK SHEET:8", "ManwayCutOut")
Here it goes through each occurrence and looks for 'COURSE 1 STEEL TANK SHEET:8' which is the occurrence of the part that I want on the different model state. (So part such as COURSE 1 STEEL TANK SHEET:1 will still be set to Master model state.)
The issue is that it will not then run the last line. We get a lovely unspecified error. The rule 'ManwayCutOut' does exist in this part. If I go and delete the new ModelState and have every thing back on Master I can run this one line fine...
Had issues with the following line too
Parameter("COURSE 1 STEEL TANK SHEET:" & BespokeSheet, "ManwayType") = MWAY_TYPE
Which again if I delete the new ModelState and have everything back on Master I can run both the parameter line and the ilogicvb.runrule line.
Tried a different approach with setting everything to the new Model State and then running the issue lines but still get the unspecified error...
Any advise/help??
