10-26-2021
11:42 AM
- Mute
- Permalink
- Report
10-26-2021
11:42 AM
This might get you closer to your goal.
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
'define the variable "oName"
oName = "ModelState1"
For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences
If TypeOf oOcc.Definition Is PartComponentDefinition Then
Dim oPDef As PartComponentDefinition = oOcc.Definition
Dim oFound As Boolean = False
For Each oMS As ModelState In oPDef.ModelStates
If oMS.Name = oName Then
oFound = True
Exit For 'found it, so don't create it
End If
Next
If oFound = False Then
'did not find it, so create it
oPDef.ModelStates.Add(oName)
End If
oOcc.ActiveModelState = oName
End If
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS)
If you want and have time, I would appreciate your Vote(s) for My IDEAS
or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
