JamesMeBoi
588 Views, 1 Reply
Using a save as in ILogic
I have a sub assembly inside my template assembly which needs to be save as'd every time the template is saved, because of the use of parameters to make a new set of tooling every time. I have 4 instants of one of the parts inside this sub assembly. Its part file is named Pouch with the respective names in the model tree, Pouch:1, Pouch:2, Pouch:3, and Pouch:4.
Here is my code, in my top level assembly.
iLogicVb.RunRule("Kanga Tooling Template:1", "Save As Rule")
iLogicVb.RunRule("Kanga Tooling Gasket Template:1", "Save As Rule")
iLogicVb.RunRule("Kanga Tooling Template Gasket Side:1", "Save As Rule")
iLogicVb.RunRule("Pouch:???????", "Save As Rule")
iLogicVb.RunRule("Tooling Assembly:1", "Save As Rule")
  Each of these 4 parts and 1 Assembly contain this same snippet of code as seen below which is a Save As command,
'define the active document
oDoc = ThisDoc.Document
CurrentFileName = ThisDoc.PathAndFileName(False)
'create a file dialog box
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
Dim Filetype As String
'check file type and set dialog filter
If oDoc.DocumentType = kPartDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
    Filetype = ".ipt"
ElseIf oDoc.DocumentType = kAssemblyDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
    Filetype = ".iam"
ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
    Filetype = ".idw"
End If
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = ThisDoc.FileName(False) 'without extension
'work with an error created by the user backing out of the save
oFileDlg.CancelError = True
On Error Resume Next
'specify the file dialog as a save dialog (rather than a open dialog)
oFileDlg.ShowSave()
'catch an empty string in the imput
If Err.Number <> 0 Then
    'MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
ElseIf oFileDlg.FileName <> "" Then
    MyFile = oFileDlg.FileName
    'save the file
    oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As
    NewDocPathName = ThisDoc.PathAndFileName(False)
    'open original drawing
    oDestinationDoc = ThisApplication.Documents.Open(CurrentFileName & ".idw")
    oDestinationDoc.saveas(NewDocPathName & ".idw",False)
    oDestinationDoc.Close
    'open new drawing
    oDestinationDoc = ThisApplication.Documents.Open(NewDocPathName & ".idw")
    Dim oDocDescriptor As DocumentDescriptor
    oDocDescriptor = oDestinationDoc.ReferencedDocumentDescriptors.Item(1)
    Dim oFileDescriptor As FileDescriptor
    oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
    oFileDescriptor.ReplaceReference(NewDocPathName & Filetype)
    oDestinationDoc.Update()
    oDestinationDoc.Save
End If
What can I put in the ??????? section next to pouch to run the code for the Pouch Part File instead of having to save it 4 times.
Thanks in advance
