Ralf_Krieg
in reply to: breinkemeyer
Hello
Thanks for the files. I picked the part "Flight" in the part name to identify the parts we need.
The script is not perfect, but works so far.
Option Explicit on
Dim oApp As Inventor.Application= ThisApplication
Dim oDrawDoc As DrawingDocument = oApp.ActiveDocument
Dim oAssDoc As AssemblyDocument= oDrawDoc.ReferencedDocuments(1) 'we assume there is only one
Dim oObjColl As ObjectCollection = oApp.TransientObjects.CreateObjectCollection
Dim oOccs As ComponentOccurrencesEnumerator
Dim oOcc As ComponentOccurrence
Dim oDrawView As DrawingView
Dim oDrawCurves As DrawingCurvesEnumerator
Dim oDrawCurve As DrawingCurve
Dim oDrawCurveSeg As DrawingCurveSegment
Dim oRefedDoc As Document
Dim oTrans As Transaction = oApp.TransactionManager.StartTransaction(oDrawDoc, "HideLines")
For Each oDrawView In oDrawDoc.ActiveSheet.DrawingViews
    If oDrawView.ViewType = DrawingViewTypeEnum.kStandardDrawingViewType Then
        For Each oRefedDoc In oAssDoc.AllReferencedDocuments
            If InStr(oRefedDoc.FullFileName, "Flight") Then
                oOccs = oAssDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefedDoc)
                For Each oOcc In oOccs
                    oDrawCurves = oDrawView.DrawingCurves(oOcc)
                    For Each oDrawCurve In oDrawCurves
                        For Each oDrawCurveSeg In oDrawCurve.Segments
                            If oDrawCurveSeg.HiddenLine = True Then
                                oDrawCurveSeg.Visible = False
                            End If
                        Next
                    Next
                Next
                oDrawCurves = Nothing
            End If
            oOccs = Nothing
        Next
    End If
Next
oTrans.End
R. Krieg
RKW Solutions
www.rkw-solutions.com
