oransen
in reply to: JelteDeJong
@JelteDeJong, again many thanks for your reply, after a bit of juggling I got this to work:
// Adding a button and a command into an Inventor ribbon
// 2021-10-18 : Started
using System;
using System.Drawing;
using System.Runtime.InteropServices;
using System.Windows.Forms;
using Inventor;
using Microsoft.Win32;
namespace InventorAddIn1
    /// <summary>
    /// This is the primary AddIn Server class that implements the ApplicationAddInServer interface
    /// that all Inventor AddIns are required to implement. The communication between Inventor and
    /// the AddIn is via the methods on this interface.
    /// </summary>
    [GuidAttribute("bc7a9e92-f455-431d-9378-c791092de1cc")]
    public class StandardAddInServer : Inventor.ApplicationAddInServer
        #region Data Members
        // Inventor application object...
        private Inventor.Application m_inventorApplication;
        // The button I will add in...
        private ButtonDefinition m_sampleButton = null;
        #endregion
        public StandardAddInServer()
        #region ApplicationAddInServer Members
        // Inventor will call this if it finds a (this) DLL in the appropriate place, for example
        // C:\Users\ofr\AppData\Roaming\Autodesk\ApplicationPlugins\InventorAddIn1\InventorAddIn1.dll
        // We are passed Inventor application which me must hold and cherish...
        public void Activate(Inventor.ApplicationAddInSite addInSiteObject, bool firstTime)
            // This method is called by Inventor when it loads the addin.
            // The AddInSiteObject provides access to the Inventor Application object.
            // The FirstTime flag indicates if the addin is loaded for the first time.
            m_inventorApplication = addInSiteObject.Application;
            // I use try-catch because Inventor swallows the exceptions silently and does not
            // warn you or the user that anything has gone wrong. The catch will give you a clue
            // if something does go wrong...
            try
                // This was me checking that m_inventorApplication is initialized properly
                MessageBox.Show("locale=" + m_inventorApplication.Locale.ToString()) ;
                var cmdMgr = m_inventorApplication.CommandManager;
                // Create the button (without icons, icons appear to be tricky)...
                m_sampleButton = cmdMgr.ControlDefinitions.AddButtonDefinition("Command 1", // Display name
        "Command 1", // Internal name
        CommandTypesEnum.kQueryOnlyCmdType, // No changes, just looking
        Guid.NewGuid().ToString(), // Invent an id for this command
        "Command 1 description",
        "Command 1 Tooltip"); // shows when mouse hovers
                m_sampleButton.OnExecute += ButtonDef_OnExecute; // Tell the button what it should do when clicked, see function below
#if false
                // If you want show the name of each ribbon....
                foreach (Ribbon r in m_inventorApplication.UserInterfaceManager.Ribbons)
                    MessageBox.Show(r.InternalName);
#endif
                // Which of these Ribbons (lines) you choose depends on whether you plug in handles Parts or Assemblies...
                // Ribbon TheRibbon = m_inventorApplication.UserInterfaceManager.Ribbons["Part"]; // command active when a part doc is active is open
                Ribbon TheRibbon = m_inventorApplication.UserInterfaceManager.Ribbons["Assembly"]; // command active when an assembly doc is active
#if false
                // If you want show the name of each tab in the ribbon....
                foreach (RibbonTab t in partRibbon.RibbonTabs)
                    MessageBox.Show(t.InternalName);
#endif
                RibbonTab toolsTab = TheRibbon.RibbonTabs["id_TabTools"]; // tools is present in both parts and assemblies
                // MessageBox.Show ("tools tab internal name = " + toolsTab.InternalName);
                RibbonPanel customPanel = toolsTab.RibbonPanels.Add("Sample", "MysSample", Guid.NewGuid().ToString());
                // MessageBox.Show("Custom panel internal name = " + customPanel.InternalName);
                customPanel.CommandControls.AddButton(m_sampleButton);
            catch (Exception Err)
                MessageBox.Show("Error " + Err.Message);
            MessageBox.Show ("Plugin loaded");
        // This is the function you added to the button a few lines above
        private void ButtonDef_OnExecute(NameValueMap Context)
            // This is a test of calling a standard Inventor command...
            m_inventorApplication.CommandManager.ControlDefinitions["AppZoomallCmd"].Execute();
            // This is my simple test of something I do...
            MessageBox.Show("My Command Called");
        public void Deactivate()
            // This method is called by Inventor when the AddIn is unloaded.
            // The AddIn will be unloaded either manually by the user or
            // when the Inventor session is terminated
            // TODO: Add ApplicationAddInServer.Deactivate implementation
            // Release objects.
            m_inventorApplication = null;
            GC.Collect();
            GC.WaitForPendingFinalizers();
        public void ExecuteCommand(int commandID)
            // Note:this method is now obsolete, you should use the
            // ControlDefinition functionality for implementing commands.
        public object Automation
            // This property is provided to allow the AddIn to expose an API
            // of its own to other programs. Typically, this  would be done by
            // implementing the AddIn's API interface in a class and returning
            // that class object through this property.
            get
                // TODO: Add ApplicationAddInServer.Automation getter implementation
                return null;
#endregion
