This github library makes it easy to work with content center and assemblies
https://github.com/HYMMA/InventorToolBox
//connect to inventor
var app = App.Start();
//generate file name
var partName = System.IO.Path.Combine(System.Environment.GetFolderPath(System.Environment.SpecialFolder.MyDocuments), "PartFileName.ipt");
var assyName =System.IO.Path.Combine(System.Environment.GetFolderPath(System.Environment.SpecialFolder.MyDocuments), "AssemblyFileName.iam");
PartDocument part;
AssemblyDocument assembly;
//make a new part document or open it if already exists
            try
                part = app.NewPart(partName);
            catch (Exception)
                part = app.Open(partName, false) as PartDocument;
            //make a new assembly document or open it if already exists
            try
                assembly = app.NewAssembly(assyName);
            catch (Exception)
                assembly = app.Open(assyName) as AssemblyDocument;
//set the part number proprety of the part
part.AsDocument().SetProperty(kDocumnetProperty.PartNumber, "S/S6758");
//add the part that was created to the assembly
var partOccurance = assembly.AddMemeber(part.AsDocument(), new[] { 0d, 0d, 1d }, new[] { 10d, 10d, 0d });
var contentCenterDesc = new ContentCenterItemDescriptor(row: 3, "Structural Shapes", "Angles", "BS 4848"){ CustomValue = new KeyValuePair<string, object>("B_L", 658) };
var contentCenterOccurance = assembly.AddMemeber(contentCenterDesc, new[] { 0d, 0d, 1d }, new[] { 10d, 10d, 0d });
