It is true that in Inventor 2022 they added "Any User Parameter Change" to the list in the Event Triggers dialog box.  But that is just for you to place the name of a rule (local or external rule) under the name of one of those events, then any time that event happens, it will trigger that rule to run.  Are you even using the Event Triggers dialog box, or just relying on the presence of those unquoted local parameters in that rule to cause it to run automatically?
Even before Inventor 2022, when you are using the unquoted names of local parameters (of any type) within a local rule, that should cause that local rule to be automatically ran any time the value of any of those named local parameters changes.  It's been that way for a long time.  However, if this were an external rule, those unquoted parameter names would not work anymore...it only work that way in local rules, where those parameters exist in the same document as the rule is in.
You said you were working on an assembly, right.  Does this same parameter exist in the main assembly, or one of its components, or in both the main assembly and is some of the components?  Is this parameter linked with any other parameters in any of the components, or an Excel file, or something like that?  What exactly are you controlling with these parameters?
Wesley Crihfield
(Not an Autodesk Employee)
