WCrihfield
in reply to: dibujocad
Here is a version of that same rule that will dig down through all levels under the purchased sub assemblies to set them all to Purchased, just in case that is what you really wanted.
Sub Main()
    Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
	oOccs = oAsmDoc.ComponentDefinition.Occurrences
	For Each oOcc As ComponentOccurrence In oOccs
		'If it's not an Assembly, don't process it
		If oOcc.DefinitionDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Continue For
		'If it's not Purchased, don't process it
		If oOcc.BOMStructure <> BOMStructureEnum.kPurchasedBOMStructure Then Continue For
		StepDown(oOcc.Definition.Occurrences)
	Next
End Sub
Sub StepDown(oComps As ComponentOccurrences)
	For Each oComp As ComponentOccurrence In oComps
		If oComp.BOMStructure <> BOMStructureEnum.kPurchasedBOMStructure Then
			oComp.BOMStructure =BOMStructureEnum.kPurchasedBOMStructure
		End If
		If oComp.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			StepDown(oComp.Definition.Occurrences)
		End If
	Next
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
