JelteDeJong
in reply to: j_weber
That rule was only to show how you can read csv files not to set them as parameters. The following rule will read the csv and also set the parameters.
Sub Main()
    Dim doc As PartDocument = ThisDoc.Document
    Dim userParameters As UserParameters = doc.
        ComponentDefinition.Parameters.UserParameters
    Dim csvData As Dictionary(Of String, String) = ReadCSV("c:\temp\test.csv")
    For Each item As KeyValuePair(Of String, String) In csvData
        SetParameter(userParameters, item.Key, item.Value)
    Next
End Sub
Public Function ReadCSV(fileName As String)
    Dim splitChar As String = ","
    Dim csvData As Dictionary(Of String, String) = New Dictionary(Of String, String)()
    Using reader As New IO.StreamReader("c:\temp\test.csv", Text.Encoding.Default)
        Dim line As String = reader.ReadLine
        Do While (Not line Is Nothing)
            Try
                Dim splittedLine As String() = line.Split(splitChar)
                csvData.Add(splittedLine(0), splittedLine(1))
            Catch ex As Exception
                MsgBox("Could not add data from line: " & line)
            End Try
            line = reader.ReadLine
        Loop
    End Using
    Return csvData
End Function
Public Sub SetParameter(userParameters As UserParameters, name As String, expresion As String)
    Dim foundPara As UserParameter = userParameters.Cast(Of UserParameter).
        Where(Function(p)
                  Return p.Name.Equals(name)
              End Function).FirstOrDefault()
    If (foundPara Is Nothing) Then
        userParameters.AddByExpression(name, expresion, "mm")
    Else
        foundPara.Expression = expresion
    End If
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
