leoa.87
in reply to: Ralf_Krieg
if I put this code inside yours, I can get the basic list with the components I need (managed by other ilogic rules)
but this rule reports me an error for each subassembly that is inside.
(Rule error: Parameters xxx.iam, document: xxx.iam
Component.IsActive: Could not change the suppression status of the lining component xxx: 1.
The active level of detail in xxx is not a custom level of detail.
giving ok. it goes on and carries out the export of the list but it is very annoying.
how could i solve?
Dim oDock As Document = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition = oDock.ComponentDefinition
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("Principale").activate
oDock.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Principale").activate
Dim ExportSheet = sFolder  & "\"  & "Parts Only " & Parameter("d109") & ".xls"
'oAsmDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
'' Export the BOM view
Dim oPartsOnlyBOMView As BOMView
oPartsOnlyBOMView = oBOM.BOMViews.Item("Solo parti")
oPartsOnlyBOMView.Export(ExportSheet, kMicrosoftExcelFormat)
Try
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Item("View1").activate
Catch
oAsmCompDef.RepresentationsManager.DesignViewRepresentations.Add("View1")
End Try
Try
oDock.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Livello di dettaglio1").activate
Catch
oDock.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations.Add("Livello di dettaglio1")
End Try
