By which means are you changing the value of that parameter when it is not triggering the rule to run...parameters dialog box, local iLogic Form, global iLogic Form, or other means?  Are you directly changing the value of that parameter named "BreedteChassisAchter ", or are you just changing the value of the other two parameters involved ("BreedteAanslag " & "BreedteMontageOnder ")?  If you are using a global iLogic Form, you will definitely need to use either the Apply or OK button before it will send those parameter changes to the document, and even then, if what you changed didn't change the value of that one parameter you are using in the rule, it will not cause the rule to run.  If using a local iLogic Form or the parameters dialog box, that should cause the parameter values to change immediately, without needing to use Apply or OK, but still if that one parameter's value was not changed, it will not cause the rule to be triggered.
Wesley Crihfield
(Not an Autodesk Employee)
