dibujocad
679 Views, 8 Replies
Change BOMStructure to subassembly when the BOMStructure of assembly is Purchased
Hi everybody! I'm trying to write a macro in order to change BOMStructure of all subcomponents when the BOMStructure of assembly parent is "purchased"
I mean:
1   Assembly --> BOMStructure=Purchased
    1.1 Component 1 -->  BOMStructure=Normal (change to "purchased")
       1.1.2  Component 1 -->  BOMStructure=Normal (change to "purchased")
I found some macro codes which allow transverse through the subassemblies of an assembly, but I'm not able to change the BOMStructure of subassemblies. Any suggestion how could I manage it?
This is the code I've recently found in this forum:
Public Sub Main()
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, _
                             Level As Integer)
    Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
    Try
    oOcc.Definition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
    Catch
    'MsgBox(oOcc.Name & "remains unchanged")
    End Try
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
        End If
    Next
End Sub
Labels (1)
