daniel.puchta
in reply to: j.haggenjos
Thank you, it works!
Here is the final code:
Sub Main()
    Dim oAsmDoc As Inventor.AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = oAsmDoc.ComponentDefinition
    Dim oOccurrences As ComponentOccurrences
    Set oOccurrences = oAsmCompDef.Occurrences
    Zapnuti_occurrence oOccurrences, oAsmDoc
End Sub
Sub Zapnuti_occurrence(oOccurrences As ComponentOccurrences, oDoc As Inventor.AssemblyDocument)
    Dim oSuppress_Occurrence As Boolean
    Dim oModelState As ModelState
    Dim oModelState_created As Boolean
    oModelState_created = False
    For Each oOccurrence In oOccurrences 'tady to změnit na list
        oSuppress_Occurrence = False
        If oOccurrence.Suppressed = True Then
            oOccurrence.Unsuppress
            oSuppress_Occurrence = True
        End If
        'do stuff...
        'If oSuppress_Occurrence = True Then
        '    oSuppress_Occurrence = False
        '    oOccurrence.Suppress
        'End If
        If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
            If InStr(oOccurrence.Definition.Document.DisplayName, new_element) = 0 Then
                oDoc.Update
            End If
            Set oDoc = ThisApplication.Documents.Open(oOccurrence.Definition.Document.FullFileName)
            Zapnuti_occurrence oDoc.ComponentDefinition.Occurrences, oDoc
            oDoc.Save2
            oDoc.Close
        End If
    Next
End Sub
