10-12-2021
12:48 AM
- Mute
- Permalink
- Report
10-12-2021
12:48 AM
Thank you for your advice, could you be more specific what do you meant? Maybe post example of code?
I have modified the code that it is unsuppressing suboccurrences but this does not work (it throws error).
Heres the code:
Sub Main()
Dim oAsmDoc As Inventor.AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
' Dim oAsmCompDef As AssemblyComponentDefinition
' Set oAsmCompDef = oAsmDoc.ComponentDefinition
' Dim oOccurrences As ComponentOccurrences
' Set oOccurrences = oAsmCompDef.Occurrences
Zapnuti_occurrence oAsmDoc
End Sub
Sub Zapnuti_occurrence(oDoc As Inventor.AssemblyDocument)
Set oAsmCompDef = oDoc.ComponentDefinition
Dim oSubOccurrence As ComponentOccurrence
Dim oOccurrence As ComponentOccurrence
' Dim oSuppress_Occurrence As Boolean
' Dim oModelState As ModelState
' Dim oModelState_created As Boolean
' oModelState_created = False
For Each oOccurrence In oOccurrences 'tady to změnit na list
' oSuppress_Occurrence = False
If oOccurrence.Suppressed = True Then
' If oModelState_created = False Then
' Set oModelState = ThisApplication.ActiveDocument.ComponentDefinition.ModelStates.Add("Part2Suppressed2")
' End If
oOccurrence.Unsuppress
' oSuppress_Occurrence = True
End If
'do stuff...
'If oSuppress_Occurrence = True Then
' oOccurrence.Suppress
'End If
If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
Dim oSubAsmCompDoc As AssemblyDocument
Set oSubAsmCompDoc = oOccurrence.Definition.Document
' If InStr(oOccurrence.Definition.Document.DisplayName, new_element) = 0 Then
' oDoc.Update
' End If
' oDoc = ThisApplication.Documents.Open(oOccurrence.Definition.Document.FullFileName)
For Each oSubOccurrence In oOccurrence.SubOccurrences
If oSubOccurrence.Suppressed = True Then
' End If
oSubOccurrence.Unsuppress
End If
Next
Call Zapnuti_occurrence(oSubAsmCompDoc)
' oDoc.Save2
' oDoc.Close
End If
Next
End Sub
